跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
Replaced glass, adhesive between digitizer & LCD
I replaced my glass on my iPhone 5c. After I was finished I noticed I had adhesive leak in between the the digitizer and the LCD screen. Everything still works but its very annoying. Is there anything I can do other than complete replacement of the LCD, Digitizer and Glass?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
not really, besides going at it extremely carefully with a small scalpel blade perhaps? otherwise you'll have to open it again.
这个答案有帮助吗?
得分 1
添加一条评论
What you are talking about it actually in the backlight. There is a couple different options for fixing it. The first option would be to completely remove that backlight, cable and all from that assembly and solder on another, iPhone 5 backlight might work, not sure. Your other option, if soldering is out of the question, would be to remove the film and filters from an iPhone 5 backlight and place on the 5c LED strip of the 5c backlight. Be careful with the LCD tho, expensive stuff.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joseph Corraini 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 719
