跳转到主内容
Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
218 个问题 查看全部
Ipad 4 lcd doesn't work properly after digitizer replacement
Hello,
I have searched on ifixit database, but I haven't found the exact problem I have.
About 1 week ago I replaced the digitizer because it got broken. Things looked ok but after a week the Lcd, when working, suddenly gets totally blurred and impossible to do anything.
If i turn off the screen with the power button (sleep mode), and then turn on again, you see the image ok for 4-5 seconds and then it gets blurred again, so I dont know if it's because the motherboard, the lcd flex... Or whatever.
The image can be shown properly for some seconds, then, I assume that, more or less the hardware involved is not damaged.
I've tried to update to ios 7.0.4 and to restore ipad but the problem persist. Any help in this regard will be very much appreciated.
Best regards
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
Any dark red color appears? If it does, afaik from many other tablets its a bad sign, the dark red i mean is like a halo visible all over the display and blends with everything, like juxtaposed.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Marc Alama 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 9
总计 459
