Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
442 个问题 查看全部
Battery not powering Mac, New Battery, New Power Logic Cable.
Hi,
i have replaced the Battery, and Logic board battery cable, computer still only works with the AC, turns off IMMEDIATELY after AC is removed... is the next step a new logic board??? $600 question....
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
善于维修,即天赋异禀。
与 #ImAGenius 分享您的维修故事
我们都是天才
1个答案
已选择的解决方案
Help us help you. The more we know for certain the more help we can be.
The trigger that caused you to decide to replace the battery and logic board cable certainly can could be the reason why the machine suddenly shuts down after the AC power supply is disconnected.
If there was a liquid spill it would not be out of line to replace a damaged logic board, and a liquid spill could cause the problem you're having. So might a power surge.
Examine the logic board under a magnifier… look closely for burn marks, corrosion or swollen components. If you find some that would indicate a logic board replacement… DIY component replacement requires special tools, solder and lots & lots of practice… it's nothing like soldering a lamp cord.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
按维修分数 1
添加一条评论
添加你的答案
logan 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 101
