跳转到主内容
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
312 个问题 查看全部
Faulty LED replacement instruction
Hi All,
After getting flickering screen which then got worst and then all am getting is blank screen I took my MacBook Air to Apple store and genius there confirmed to me the fault is with the LED and not the screen itself.
What he did he flashed a light to the back of the screen were the apple logo is and en you can actually what is on the screen.
Apple advice was to replace the whole display assembly which cost almost the same as much as I paid for the MacBook Air itself..
Is it possible to replace only the LED ?
Thanks in advanced
Ahmed
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Yes it can be done. It is a very '''advanced DIY project'entailing dismantling and reassembling much of the laptop.'' I would not start this as a first DIY laptop repair.
Almost as difficult is just replacing the display with the top cover already included.
For either you need the proper tools (every job is easier with the correct tools.)
You need to study (not just read) the guide - many DIYers do more damage when they tear components off the logic board by not unlocking cams, or pulling the wrong direction.
Once you get your old display out on the back you will find the manufacturer's part number which will allow you to find replacement screens. The display alone would not cost as much as the preassembled display & cover - (but time is also costly) .
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 1
2条评论:
Thank machead3 for your answer but am interested if I can do any troubleshooting steps to repair the LED without replacing the whole screen ?
I had a look on eBay and the screen itself is not expensive however many posts on this website describe how replacing the LCD didn't fix the LED backlight issue..
So do I need to change the LCD cable, fuse or the whole screen ?
Thanks again and Merry Christmas :)
完成的
Doing a "shade tree mechanics" version the cable is cheapest and easiest, then the display, lastly the controller/fuse (that really is not a job for an amateur- soldering logic board components requires special tools, solder and lots and lots of experience as it's easy to burn through a multilayer board). Not to mention obtaining the part… generally a DIY "fix" is an entire logic board replacement.
完成的
添加一条评论
添加你的答案
ahammadi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,006
