跳转到主内容
雅达利视频电脑系统(VCS)有MOS科技的 6507 CPU ,频率为1.19MHz
31 个问题 查看全部
Atari 2600 RCA Video Input
How do you change the video on the Atari 2600 to input to the TV using RCA instead of the one line with a antenna input adapter. Similar to PlayStation or NES
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
rachelsmith9473, the Atari 2600 was originally designed to output an RF modulated signal. That means the audio and video signals were combined into one signal. There are several Vid Mods out for the Atari, to convert to either composite or even S-Video. My favorite is the one from here. You can purchase it complete, as a kit or see the attached images for a DIY solution. Also, check this site for another mod. Hope this helps, good luck.
Part Mouser Part Number Quantity
100uF Cap 140-L16V100-RC 1
.1uF Cap 581-5ZH104ZEDAA 2
10uF Cap 810-FK20X7R1C106M 1
1uF Cap 140-L50V1.0-RC 2
1N914 512-1N914BTR 1
2N3904 512-2N3904BU 1
1.5K 660-CFS1/4CT52R152J 1
10 660-CFS1/4CT52R100J 1
9.1K 660-CFS1/4CT52R912J 1
36K 660-CFS1/4CT52R363J 1
18K 660-CFS1/4CT52R183J 1
75 660-CFS1/4CT52R750J 10
2K 660-CFS1/4CT52R202J 1
1.6K 660-CFS1/4CT52R162J 1
680 660-CFS1/4CT52R681J 1
1K 660-CFS1/4C102J 1
1.8K 660-CFS1/4CT52R182J 2
CD74HC4050E 595-CD74HC4050E 1
FMS6400 512-FMS6400CSX 1
S-Video Jack 161-2104 1
RCA Jack Y 502-BPJF04X 1 502-BPJF04AUX
RCA Jack W 502-BPJF03X 1 502-BPJF03AUX
RCA Jack R 502-BPJF02X 1 502-BPJF02AUX
Wire 523-111-2213-010FT 1
from here.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rachelsmith9473 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,358
