跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
Can not power on after replacing power button
my iphone 4s was having problem with the power button, i have to press very hard to get it to work. i got a replacement power button flex cable and replace it. but after the replacement, the power button completely stop working. I swap back the old cable/button, its not working either. What could be causing this? thanks
  • it does power on after i plug in the cable to the computer.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
There are a couple of issues. A couple times I have looked at this issue it ended up being that one or both of the screws on the power button retaining bracket were not installed. Does the button make clear clicks when depressed? It shouldn't be hard.
Check your cables for folds, tears or rips. Check the port the cable plugs into for dust, debris, or broken solder points. Is this phone still recognized by iTunes?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
cli168 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 77
