跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
Display still dark after new display and board
I have a MacBook A1181 2.0GHz mid 2007 with a dark display (random). I could make it work by putting the brightness the whole way down and then back up again, but that stopped working. I put another, known good, display on it and that didn't help. So, I put in a new logic board. It worked until I closed the lid and opened it back up. Now it's dark again and I can't get it to go bright again.
I have read that another problem part could be the inverter cable, but isn't that connected to the display? If I put on a new display that would mean the inverter cable would be o.k., right?
I'm at a loss now as to what to check/replace.
Any advice would be greatly appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Assuming the replacement screen assembly and board are known-good (have you seen them both working with your own eyes?), you've ruled out pretty much all the hardware. Yes, the inverter and inverter cable are part of the display assembly. A1181 inverters just about never go bad, but the cables do fairly often. The screens go out even more often than the inverter cable.
I am not 100% sure from the description of your laptop, but judging from the symptoms I'm willing to bet you have an 820-2279-A board (the number is printed under the right RAM module) with a 3-wall inverter cable (flat and thin connector, rather than the big and chunky 4-wall that plugs in from the top). 3-wall means the socket on the board has 3 surrounding edges and is open on one edge, whereas the 4-wall socket has plastic edges all the way around, and so you plug in from the top.
Anyway, the 3-wall cable has 4 wires that go into tiny holes on the connector at the end of the cable, which in turn goes into the socket on the board. The 4 wires are notorious for coming just slightly loose and causing the behavior you are witnessing. They are not necessarily even disconnected from the plastic connector, but if you look carefully you can see through the tiny slits on the connector that they may not be fully seated. While it is connected to the board, you can use a good pair of tweezers to grab each wire and push it all the way in.
Also, the fact that the motion of moving the screen hinge is apparently tugging on the inverter cable suggests that you may have screwed down the left screen hinge onto the inverter cable improperly. You may want to remove the left screen hinge bracket (the piece that has 3 screws in it), and see if you can adjust the inverter cable a little, and give it some more slack.
这个答案有帮助吗?
得分 1
添加一条评论
When you replaced the display did you replace the Inverter as well? It sounds like that is what you need to do here as well as the inverter cable. Heres the IFIXIT Guide to do the job: MacBook Core 2 Duo Inverter Replacement
这个答案有帮助吗?
得分 0
1条评论:
I didn't explain what I did correctly (so sorry). I replaced the ENTIRE display assembly, not just the LCD panel. The display assembly came off of a working MacBook. Isn't the inverter in the bottom part of the display assembly?
完成的
添加一条评论
添加你的答案
lshiflett 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 85
