跳转到主内容
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
430 个问题 查看全部
HDD Fan speed 0, CPU fan speed at maximum
I tried to add a SSD, to my iMac 21.5 2011.
I followed the steps from the guides (iMac Intel 21.5" (Mid 2011) Dual Hard Drive Kit). I din't have a SATA power cable, so I used a power spitter. I took the power from the HDD and split it to the SSD.
The iMac found the SSD and its HDD, but the fans went crazy.
The optical drive fan works as it should (I left the thermal sensor). The HDD drive fan indicates 0rpm, and the CPU fan goes at full throttle.
I removed the SSD and left only the HDD. But the fans remained the same.
I also tried http://www.hddfancontrol.com/ but it's not doing anything for the fans.
Any tips or info, that would help me solve this, is appreciated.
iMac Intel 21.5" (Mid 2011) Dual Hard Drive Kit图片
产品
$27.99
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Try an SMC reset - your kluge may have caused problems with the EFI. Fans run at high speed by default if temp sensors report out of range or failed (your HDD fan sensor could be the cause of the fan problem). If the reset doesn't work you'll have to figure out if a fan is indeed shot.
A fan control app should work - but with one fan out you could cook you CPU so I wouldn't use one anyway.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 1
添加一条评论
I found the problem. I haven't connected the HDD fan to it's power socket. (>_>).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ispas Adrian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 883
