My TEKA gas oven does not stay on.
I turn my oven on to the maximum temperature, it heats up for a while, to around 350-400 degrees, then goes out. I can re-light it, but it usually goes out again after a short time. It never reaches max temp.
Oven Igniter
Even though the oven igniter may be glowing, it may be too weak to allow the gas valve to open. If the oven won't heat and the oven igniter glows for more than 90 seconds without igniting the gas flame, the oven igniter should be replaced. This is the most common part that fails when the oven won't heat.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,284
