跳转到主内容
An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
156 个问题 查看全部
Why will my Gameboy Advanced SP will not charge or turn on?
I got a GBA SP from my friends and I tried turning it on but it would not turn on. I then plugged it in to the charger. It flashed orange really quickly and then would stop charging. (Note: My OTHER friend said that the battery swells up on those things and it looks like that might be the case but I don't know how to fix that either.) If someone could help me figure that out I would be pretty happy!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
5条评论:
Same thing for me, but the battery replacement didn't work
完成的
I've diagnosed the problem with mine, the wiring between the charging port and the battery is somehow broken.
完成的
Same problem
完成的
Do a bridge on the F2 fuse.
完成的
i have that same problem
完成的
添加一条评论
4个答案
Tommy the very first thing you want to do is to change your battery. Here is the guide for it. The battery is available at places like this. Hope this helps, good luck.
这个答案有帮助吗?
得分 0
1条评论:
Already did. No help
完成的
添加一条评论
I think you should bye a new gameBoy Advanced SP
这个答案有帮助吗?
得分 0
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
All you need is a new battery :)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tommy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 12,431
