跳转到主内容
PlayStation 3 Slim是Sony Computer Entertainment生产的PS3视频游戏机的第二版。 它于2009年9月1日发布。
465 个问题 查看全部
问题已关闭
Stripped screws EMI shield PS3, can't get them out. Help please!
'''Hello,
The bottom two screws on the motherboard assembly wont loosen at all as they both have been stripped.
I was using the correct screwdriver but they were so !@#$ tight and I didnt have enough power to get them out so they stripped when I tried.
Picture to show what screws I mean:'''
Does anyone have any idea on how to get the stripped screws out ? I don't want to break the motherboard or anything else.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
First of all, why do you want to assemble your motherboard?
Hereby a solution with limited damage.
The only thing left to do is to drill out the screws preferably with a small pillar drill, and use a brandnew drill the same diameter as the screw. With a pillar drill you won't slip beside the head of the screw. It is important that you do this gentle.
The only negative thing about this is you can't use the screws and holes anymore but some times you won't need them. Good luck.
这个答案有帮助吗?
得分 0
添加一条评论
If you have a very small angle grinder, such as dremel, you can use it to cut a groove suiteble for a flathead screwdriver. You would have to protect the rest of the mobo from sparks and have a very steady hand. Slip once and it's over.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,012
