Apple的 MacBook Pro 的產品線是專為可望極致效能專業使用者所打造。MacBook Pro 产品线包括了MacBook Pro 13" (一體成型機身款), MacBook Pro 15", MacBook Pro 15"(一體成型機款), MacBook Pro 17" 和 MacBook Pro 17" (一體成型機款)。
14525 个问题 查看全部
Why does my MacBook Pro click?
There is a constant clicking when MacBook Pro is on.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
From where is the click coming from?
Can you please specify which model you have?
Please search existing posts before asking standart questions. Could be a dying harddrive.
That's not a very nice and welcoming comment reMacberlin.
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
4个回答
已选择的解决方案
Three possibilities for a clicking noise. 1. Optical drive (unlikely) 2. Fans (tossup) 3. Hard drive (very likely) If the computer were mine I make sure I had a good backup and replace the drive. Since you didn't say which model you have I am including the repair guide for the Core 2 Duo. I will also include guides for identifying your computer and for possible replacement hard drives. Ralph
MacBook Core 2 Duo Hard Drive Replacement
http://www.ifixit.com/Info/ID-your-Mac
http://www.ifixit.com/Mac-Parts/MacBook-...
这个答案有帮助吗?
按维修分数 5
评论:
Agreed, probable hard drive failure +
Agree with HDD failure +
添加一条评论
I have a Macbook Pro that had the exact same problem, well that was not a problem actually.
Does it happen when you lift or move your macbook pro while turned on ? It probably comes from the HDD, it is called the Sudden Motion Sensor (SMS)
When the system detects sudden acceleration (such as when the computer is dropped). It disengages the disk heads from the hard disk platters, preventing data loss and drive damage from a disk head crash. As it must be really fast when it hit the floor for example, it produces the "click" sound.
If you want to make sure that it's the reason why it clicks, hold your mac while powered and shake it a little, if it clicks, that'll be ok.
这个答案有帮助吗?
按维修分数 2
添加一条评论
If you hear the clicking while using the computer ...
My bf had the same 'problem' until we figured out it was the ticking of the trackpad :))) just turn that off in system preferences
这个答案有帮助吗?
按维修分数 0
添加一条评论
I've noticed some of the mac laptops' fans make a 'tick tick tick tick 'sound; very very very subtle.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Tony 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 1,141
