跳转到主内容
The Sony Vaio VGN-FS640 laptop was released in 2005.
10 个问题 查看全部
问题已关闭
The "W" key stops responding
How to fix the keyboard on the Sony Vaio PCG-7A2L?, I've tried to use contact cleaner on the contact board .... but the conditions on the keypad is still the same, the best solution please .... Thank you for your cooperation
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Was this machine ever in the the White House? http://abcnews.go.com/Politics/story?id=...
这个答案有帮助吗?
得分 1
7条评论:
there is a different solution?
完成的
Try hooking up an external keyboard and see if the W key works on it to eliminate any software issues.
完成的
when connected to an external key board, the "W" key board no problem ...... but after external detachable keypad button issue "W" appear again, in an application I've tried to reinstall the hardware driver, still the "W" can not be used
完成的
Remove the key and examine the sisors contraption to see if it is working. Press the peg and see if it works and puts a letter up. Here's a video on how to do it: https://www.youtube.com/watch?v=KWzWCTD1...
完成的
sorry I am new comments now, I try to clean the "W" with cotton, function only temporarily ....
carbon on the "W" no problem ...... because while it functions as a reference
完成的
显示更多的2条评论
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 135
