跳转到主内容
Released around 2010, the Dell Inspiron 15R N5010 is a 15-inch laptop with an Intel processor and dedicated ATI Radeon graphics card.
47 个问题 查看全部
I want to replace my graphics card
hi i have dell inspiron N5010 with the following configuration
System Model: Inspiron N5010
Processor: Intel(R) Core(TM) i5 CPU M 430 @ 2.27GHz (4 CPUs), ~2.3GHz
Memory: 5120MB RAM
Available OS Memory: 4982MB RAM
Card name: ATI Mobility Radeon HD 5470
Manufacturer: ATI Technologies Inc.
Chip type: ATI display adapter (0x68E0)
DAC type: Internal DAC(400MHz)
Display Memory: 2737 MB
Dedicated Memory: 502 MB
Shared Memory: 2235 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
i want to replace new grafics card 1 gb AMD Radeon HD 6630M is it possible?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
gopi krishna, your " graphics card" is actually a chipset that is part of the system board, it cannot be upgraded.
这个答案有帮助吗?
得分 2
添加一条评论
Hi,
You can not integrate any additional card into your laptop motherboard.
Good luck.
这个答案有帮助吗?
得分 0
添加一条评论
The gpu is actually dedicated not integrated so maybe it can be change my advice will be to write to DELL as that is what i'm about to do because i have same product
这个答案有帮助吗?
得分 0
2条评论:
did you get any reply??
完成的
Did anyone find a fix for N5010 graphics card issues.
完成的
添加一条评论
I had the same issue
Had my laptop reflowed .. it lasted a couple of yrs after that same problem
Then some repair guys from kolkata somehow changed it with a intel gpu for INR 4000 and it's working fine now.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
gopi krishna 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 15
总计 13,975
