跳转到主内容
Clothes dryer repair and support guides.
748 个问题 查看全部
Gas dryer drum turns but no heat
I have the Kenmore Elite Gas Dryer model number 110.74982300. The drum turns but no heat. All lint vents are clear of debris/lint. I have tested the Thermister (approx. 11K ohms), Thermal fuse (0 ohms), High limit Thermostat (0 ohms), Radiant sensor (0 ohms), Ignitor (0 ohms), Coils 1 to 2 1340 ohms, 1 to 3 549 ohms, 4 to 5 1289 ohms. All seem to be in the correct ranges.  Ignitor does not glow and thus no heat provided.
Not sure where to go from here.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Check for continuity with a multimeter:
Thermal Fuse
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Gary 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 259
