跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Constantly searching for signal.
I replaced the volume/vibrate/lock flex on my iPhone 5 and once I got it back together the phone is constantly "Searching" for the cellular network. Everything else works on the phone. I also noticed that when I eject the SIM card the phone does not display "No Sim" as it would normally. It is an AT&T iPhone 5. Does anyone have any idea what could have caused this? The cell antenna in the bottom right corner is not compromised and the interconnect cables are attached correctly. What else could cause this problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 20
添加一条评论
23个答案
最有帮助的答案
Hello Everyone.
I work at a IT Repair shop in Portugal and have a lot of experience repairing iPhones.
This started happening to me when iOS 6 came out and I had no idea what was causing this, since the hardware was all ok. Turns out that because the iPhone communicates with security certificates, you have to set the time and date right. Best way to do so is just connecting to a WiFi network and wait arround 5 seconds, then restart the phone. Otherwise, jsut set it manually (the year will be 1970, I think).
Once again, this is the solution for many network issues after unplugging the battery.
Hope it helps :)
这个答案有帮助吗?
得分 12
7条评论:
Thanks to you i fix my problem :)
完成的
I did this, but when it comes alive again, it cames No service =/ , but the same sim works im my Iphone 6 Plus (still with the problem), any other solution ?
完成的
I reassembled my iPhone5 after chamging the rear housing and had the same issue with cellular signal...This helped,thanks!
完成的
Thank you very much,i just fixed my iphone after consistent searching without networks.But after following your instructions network came up.I am grateful.Cheers!
完成的
This worked exactly as he said. Thanks a lot. Worked on my iphone 4
完成的
显示更多的2条评论
添加一条评论
I also run it the same problem and did all of tricks in the book... from taking apart the complete phone to checking all of the connectors under microscope and reseting the network settings too... nothing helped...
However the solution was much simpler in the end...
If you disconnected the battery while you were doing any repairs (as you should!) the date on the iPhone should change to the year 1970 or something like that and the connection with the cell tower is not possible... do not ask me why...
After I changed the date I got full reception right away...
I guess it would work if you reset the phone completely since the iPhone would sync with the iTunes on the computer so it should pick up the date too...
Also the connection to the wireless network could also help however at the time I was not connected to the wireless internet at all so I am not able to verify that...
So before you do anything else and have similar "searching" issue check the date first....
这个答案有帮助吗?
得分 4
2条评论:
Absolutely correct!
As I stated below, iOS communications systems depend on date/time to communicate.
In normal situations, just connecting to WiFi, would solve the problem.
完成的
it resets to thursday the 1st of janurary 1970 at 10.00 am.
in 1970 cell towers didnt exist so it will spend the next 20 to 30 years searching connect to wifi allow time to update then restart phone
完成的
添加一条评论
This happenes to me almost every time i fix a iphone 5/ 5s
I always check with soft reset, and reseting network settings. Somtimes i need to start the phone without the sim inside the phone. I have gotten it right in the end every time, but i still get nervous :)
这个答案有帮助吗?
得分 3
2条评论:
Thank you for this advice. It actually worked!
完成的
How Did IT Work i have the same problem !!
完成的
添加一条评论
Cycle airplane mode and try again
这个答案有帮助吗?
得分 2
添加一条评论
Turn off your phone & put it in a plastic bag and close it and then put it in the fridgerator for like an hour or an hour and a half this might seem weird but i swear worked for me
这个答案有帮助吗?
得分 2
1条评论:
Thanks. This is weird but worked for me. Cheers!
完成的
添加一条评论
having the same issue, replaced the volume power flex with no luck getting the service back, even cycling airplane mode wont work it will stuck on searching, even i tried to look for carriers manual but still can not see any other network..
any advice
这个答案有帮助吗?
得分 1
1条评论:
it resets to thursday the 1st of janurary 1970 at 10.00 am. in 1970 cell towers didnt exist so it will spend the next 20 to 30 years searching connect to wifi allow time to update then restart phone
完成的
添加一条评论
I tried to cycle many times with no luck. Even took apart the phone a couple if times but that Did not help eaither. Waited for a couple of hours and the phone tried do connect to wifi. After that it changed from searching to no connection. Then i cycled airplane mode or power. I do not remember which.
这个答案有帮助吗?
得分 1
添加一条评论
I was replacing a back camera on an iPhone 5 and after putting it together the device was searching for service all the time even after the basic troubleshooting tips. I even put the entire logic board in another iPhone 5 that had been working and it is still happening.
Is it possible that their sim card needs to be replaced or the phone needs to be restored?
这个答案有帮助吗?
得分 1
添加一条评论
Had the same issue here.
Solution:
- Recheck the connection of cellular data antenna (Step 15)
- Recheck the connections (Step 18)
Those connectors are tricky (IMHO). Check for damage.- I destroyed one in my old 3GS (pushed to hard) - had to have it resoldered - Be patient and carefull !!! - They have to "snap" in.
- Start the Phone - get your Sim-Card out - plug it in again.
Hope this helps.
这个答案有帮助吗?
得分 1
添加一条评论
Can you connect to wifi?
这个答案有帮助吗?
得分 1
添加一条评论
I can but I can not connect to any cellular network, there is another thing I notice is that when start the phone for the first time, the automatic date and time zone it keep searching for time and always select the wrong time zone such as Singapore , while I am placed in Yemen,
这个答案有帮助吗?
得分 1
添加一条评论
Anyone got an answer for this? have you all tried reseting your network? go to settings -> General -> Reset -> Network Reset and let me know if it works
这个答案有帮助吗?
得分 1
1条评论:
Nice! This seemed to help.. No "searching" so far...
完成的
添加一条评论
I need your help.i have the same problem with searching network .First I put my iphone on dfp mode with the wrong data and time for restoring with iTunes.
But in iTunes when the process is around 70% I have the 47 error-
Why???
Thank you for the future answers.
这个答案有帮助吗?
得分 0
添加一条评论
Sale here. After replace the power /sound flex cable i have a searching network problem. I try everything mentionned here but no way.
So i try an iTune restore and got error 47. I wait the interconnect cable to see if it could the cause.
If someone has an idea :)?
Thanks CcHuMi.
这个答案有帮助吗?
得分 0
添加一条评论
Iam getting frustrated. My iphone 5S cannot seem to detect a network. I have tried hard reset, airplane mode, resetting the network, inserting & removing the sim -- Iam trying to restore it through itunes and it comes up with an error.
Help someone please!.
这个答案有帮助吗?
得分 0
添加一条评论
I have this same problem with my 5c. I recently repaired a phone that is locked to ee. Me being on ee thought I could use this phone but I kept getting searching and occasional signal. I rung up ee and they to me that because I have a T-Mobile SIM card I have to get the phone unlocked which they won't do as its a second hand phone. Does anyone know if getting it unlocked will fix this searching problem as I am unsure?
这个答案有帮助吗?
得分 0
添加一条评论
My problem was similar. "Searching" was on top left corner. ATT store switched sim cards with no luck. So I turned phone off. Removed Sim card. Started phone w/ Sim card out. Put SIm card in when phone comes back on and it worked!! Hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
I have the same problem after replace the batrry
这个答案有帮助吗?
得分 0
1条评论:
check your time and set it correctly... either sync with WiFi
完成的
添加一条评论
I have similar problem for andoid, the cellular networks is searching and accidentally turned off how do I turn the cellular networks back to the automatic can someone help me please.
这个答案有帮助吗?
得分 0
添加一条评论
Why Apple didn't give us the solution? All we have same problem my phone from 3 days searching cellular
这个答案有帮助吗?
得分 0
1条评论:
yes I don't understand why Apple will not answer all these problems, maybe its because they don't have the savvy or knowledge to give a fix, I believe that it is a motherboard problem and Apple don't want anyone to know this or they would have to recall all the iPhone"s with this problem. I restored my phone in iTunes because of the searching problem thinking this would solve the problem, but alas no way. I have tried all of the options suggested on this problem page but to no avail. This is my first and last iPhone I will ever use, because it is in the bin. Apple you are not a very customer friendly company or you would give out solutions to fix the iPhone.
完成的
添加一条评论
Iphone 6 - Removing the sim card, powering off and back on, and reinserting the sim card resolved this issue for me. I have had the same issue sevral times before and had to call my carrier to resolve. They did not give specifics but they stated this was a known issue with Iphones. Twice they had me restore my phone and then said they reset something on their end as well.
这个答案有帮助吗?
得分 0
添加一条评论
Only way mine stopped searching and connected is if I slam it into my open hand real hard a couple times and it will work for a day or 2 then back to searching so slam it again, something is loose or?
这个答案有帮助吗?
得分 0
添加一条评论
I put mine in the road, went upstairs to my bedroom window and sat with a bowl of crisps and a bottle of cola. It wasn't long before a good sized car came along and obliterated the cunting thing.
Problem solved.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
tommycook 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 108,713
