跳转到主内容
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 个问题 查看全部
问题已关闭
After YLOD repair, controller won't connect
Hi,
I successfully used the YLOD repair kit from ifixit to repair my overheated PS3. Everything seems to work great, except the PS3 controllers will not wirelessly connect to the system. I tried resetting the controllers and also tried pressing the PS3 button down for awhile after connecting with a USB cable with no luck. Any other advice?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Can your PS3 connect to WiFi?
It sounds like you forgot to hook up the bluetooth/ wifi cable
这个答案有帮助吗?
得分 1
添加一条评论
I took it apart last weekend to check it out and the ribbon that connects the bluetooth/wifi cable popped right out...so you're right jzpittm. At least it was an easy fix. Thanks!
这个答案有帮助吗?
得分 1
添加一条评论
Hi,
I ve got the same problem : try to reset the controller (Button at the rear)
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 637
