doesn't pick up signals after screen repair
just replaced a new LCD screen mself and now the screen is working but the phone is not picking up any signals. any idea what could it be?? (i'm pretty sure I didn't damage the 3g cable. )
You need to re-check Rf cable connectors, and location of springs at the end of the RF cable (position of pcb with springs as well). It is the most likely cause of the issue.
Also check split lines of the assembled phone, if they are too big, it could mean that springs do not make proper contact. If so carefully reassemble cover.
Best of luck, Carsten
这个答案有帮助吗?
should also mention Bent springs as possible issue.- recheck.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 283
