跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
3046 个问题 查看全部
Not charging after replacement charging port. Stuck on battery empty
Hello all,
I had a issue with my loudspeaker it was much lower than my girlfriends iPhone 4S when playing music.
I bought a new speaker/mic and took it to a friend of a friend who owns a phone repair shop. He fitted the new speaker/mic and also changed the charging port. The Speaker sounded much better and I took it home ready to sell to a friend. I by mistake left the phone on and the battery drained and turned off about 4days ago. I took the phone out last night to charge for him, but it just stays on battery screen with the red bit at the bottom telling me it's empty. When I take the charger out it tells me to plug the charger in. When I place the charger in the cable image goes off and just show the red battery again. I left it in charge for 8 hours and when I woke up it still showed the battery was empty.
So my question really is, do I need a new battery or is it a faulty charging port - with it seeming to acknowledge that a charger is plugged in I'm not entirely sure.
Quick update:
Put the phone into dfu mode, iTunes detected the phone tried to restore but when it was "waiting for phone" it brings up the error code 2009" and back to the battery screen. Reset also doesn't work.
Thanks
Jay
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Well today it was in a DFU loop, and kept getting error codes in iTunes. Then it kept rebooting to apple logo - only when connected to power.
完成的
添加一条评论
1个回答
Kind of sounds like a bad charging port. I had a couple of them while repairing phones. Make sure nothing looks out of the ordinary on the battery connector.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jay 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 964
