跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
问题已关闭
Non responsive touch screen
Hello everyone!! I have an iPhone 4 that has a dead touch screen. You can see everything on the display but can not swipe the phone to use it. I have changed the screen, checked the ribbons for tears, updataed and restored. Even cleaned the contacts on the board and the screen with Isopropanol. I still have a non responsive touch screen. Anyone know what can be causing this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Sometimes after market screens will only work with the most updated version of iOS. Start there. Also, try a soft reset, let is sit for a minute, then check. If still nothing do another soft reset. If still nothing... time to check the solder points on the board. You may have a larger issue at hand.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 206
