跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
问题已关闭
Replaced screen and now phone doesn't power on?
Pretty simple, I replaced the screen on an iPhone 4S and now it will not power on or respond to hard reset or being plugged in. I do notice that after being plugged in for a minute or two, the logic board gets a little warm but still no sign of life. I've taken it apart to check and reseat the connectors three times now, I'm stumped.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hi there,
have you tried a hard reset?
If not, here's how: http://www.wikihow.com/Hard-Reset-an-iPh...
Hope this fixes your issue.
这个答案有帮助吗?
得分 0
1条评论:
I mentioned in the question that it does not respond to a hard reset.
完成的
添加一条评论
Examine the battery connector carefully. It's easy to break away from the logic board if you are less than gentle when disconnecting the battery.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 153
