跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
3008 个问题 查看全部
My iPhone's home button will not work after a front panel replacement!
I was repairing an iPhone 4S for a client, when I accidentally tore the digitiser cable. I replaced it with a new screen and so a new home button to match the colour (black). When I reassembled it, all was well, but the home button was not responding at all. I took it apart several times to look at it, I replaced the home button with one out of a donor phone, I did the same with the dock connector assembly. It still doesn't work. I tried to use the apple recommended home button calibration, but that did not work. It is running iOS7. Any help would be greatly appreciated! Thanks in advance :)
回答此问题 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
1个答案
please go to the next link: [[URL|iPhone 4S Repair|Link] and repase the instruction
God bless you
这个答案有帮助吗?
按维修分数 0
评论:
I decided just to get a new home button flex. The other thing is, now the base and chip is getting extremely hot extremely quickly and burning through battery so fast that my iMac refuses to charge it as it's drawing too much power. It did have some water damage.
添加一条评论
添加你的答案
fnqirepair 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 109
