Can I put a iPhone 5 screen on a iPhone 5s?
Can i put a iphone 5 screen on a iphone 5s?
You answered "no" as if the link you referred to answered the question. I'm not sure if it is possible, I am not saying that. However if you had an iPhone 5s LCD assembly you wouldn't need the home button it would be attached to the LCD screen you would be replacing. Before everyone just takes everyone else's word for it, because The question actually has not been answered, maybe there should be more discussion before this subject is closed. There are many reasons for wanting to do this, for one I don't use my fingerprint scanner and could care less about it. I have about five iPhone five screens and they would come in handy because like everyone else I've broken my share of screens. I understand the parts from an iPhone 5s screen will not fit with an LCD from an iPhcone 5. But can anyone say for sure that the ribbon is not the same, if I recall the iPhone 5s just has an extra ribbon for the home button for the fingerprint sensor. The iPhone 5 LCD only has the home button attached to the entire assembly. The real question would probably be, does the LCD ribbon and digitizer ribbon fit the motherboard and also will the missing fingerprint sensor cause errors with iOS.
这个答案有帮助吗?
Bobby, the answer is no. The Ribbon cables and connectors are all different. The image should help you to see the difference.
这个答案有帮助吗?
no you can't because the new home button they are different and some more part
but you always can order one good quality in the online store or ebay
I find you here one for example :
http://www.ebay.com/itm/151269627651?ssP...
I hope that its help you :)
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 14
总计 23,463
