跳转到主内容
修复你的物品
维修的权力
配件 & 工具
型号A1367,闪存容量:8、16、32及64GB
1306 个问题 查看全部
Screen flickers on and then off after screen replacement?
I replaced a screen on an iPod touch a couple of weeks ago. Everything worked fine until today. When I push the power button the screen flickers on for a split second and then turns black. During that split second I am able to see the lock screen. Also, the home button wont turn the screen on; the screen doesn't even flicker when the home button is pressed. However, I can confirm that the home button does work. After multiple tests I have eliminated a few possible causes for this problem.
1) The problem does not lie in the screen itself.
2) The problem has nothing to do with the power button.
3) It is not software related as the iPod behaves normally in every way that I can possibly test it without being able to unlock it (screen shots, voice over, hard reset, iPod restore.)
I have not been in possession of the iPod in the last two weeks, so I really don't know what it has been through. hopefully not water damage...
Anyways, any help would be appreciated. I would love to know any possible causes and hopefully any possible fixes.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
LCD iPhone 屏幕维修套装
预算选项,涵盖在我们的终身保修中。
购买套装
LCD iPhone 屏幕维修套装
削减维修成本,而不是质量。
购买套装
1个回答
Good night friend.
Your problem seems to be a bad contact on the LCD of your Ipod. Try reconect or clear contact with isopropyl alcohol. If not, it is best to replace the LCD again.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Micheale Phipps 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 325
