跳转到主内容
Released September 14, 2012, Apple's EarPod headphones are a new revision to their iconic white headphones.
55 个问题 查看全部
How do I fix the earpod plug-in
Hi
I have a chromebook and it comes with this case from school. I have apple earpods and I leave them pluged in whenever I put them in the case. When I took out the laptop, I unplugged the earpods and the part that you plug in was bent and uneven with the cord. When I got home the audio was very bad when I tried it. Then I tried pushing it back in by bitting it, then it broke off.
Can you please tell me how to attach it back on and have it still just like before?:)thanks
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 2
添加一条评论
Macbook 电池维修套装
起价 $69.99
Buy Now
Macbook 电池维修套装
起价 $69.99
Buy Now
3个回答
已选择的解决方案
luna, if you know how to solder, you can replace the 3.5mm audio plug. The repair should be similar to any audio jack repair. Something like this should give you an idea. Hope this helps, good luck.
这个答案有帮助吗?
按维修分数 2
添加一条评论
Thats not possible to repair. You just need to buy a new pair.
这个答案有帮助吗?
按维修分数 1
评论:
It's better to say You still don't know how to do it.
添加一条评论
http://www.youtube.com/watch?v=zqyVUHv4A...
这个答案有帮助吗?
按维修分数 1
添加一条评论
添加你的答案
luna 将永远感激不已
浏览统计数据:
过去的24小时: 8
过去的7天: 40
过去的30天: 201
总计 22,440
