跳转到主内容
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
140 个问题 查看全部
问题已关闭
The portafilter when attached to the machine blows out coffee
when you turn on machine and start coffee blows out from the portafilter from around the brew head where you attached to the machine
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The most likely cause of this is either an old brew head gasket that is no longer forming enough of a seal or the small plastic ramps inside the brewhead are broken or missing.; they press the portafilter up against the brew head as you rotate it. It's also possible that your basket or portafilter is clogged and/or your coffee is ground to fine, but on a properly operating machine this would not result in the blowout you're experiencing. When you attach the portafilter, does it easily turn all the way to the right or is there some resistance? Try to brew with no coffee in the basket; do you still get the blowout effect or does the water dispense through the spouts as it should?
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 377
