跳转到主内容
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
463 个问题 查看全部
My 3DS Won't turn on?
I recently bought a Nintendo 3ds and after a month of playing it, it just shut off. Every time i press the power button, the blue power light shines for three to five seconds and then shuts off with a loud powering off sound. The system never completely turns on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
最有帮助的答案
might have been dropped damaging the top screen, or the cable may have worn over time - open it up and push the top screen cable fully in
这个答案有帮助吗?
得分 1
添加一条评论
some one try this fixer.
这个答案有帮助吗?
得分 0
添加一条评论
Something in your system is causing a short. These are potential root causes of the flash power off....
1. Ribbon cables from the LCD and 3d feature are loose
2. Damage to ribbon cable for the backlight (bottom or top lcd)
3. Damaged ribbon cable connectors on mother board (corrosion or bent pins)
4. Bad 3d/backlight/speaker cable
5. Bad mother board due to fuse.
这个答案有帮助吗?
得分 0
添加一条评论
charge it
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
wingfieldjustin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 5,249
