跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3531 个问题 查看全部
How to replicate brushed aluminum sides of iPhone 5S "Space Gray"
I have already dropped my 5s. I smoothed out the smashed chamfered corner with some 2500 grit sandpaper (inspired by this guy: http://www.youtube.com/watch?v=Z31HP_2CN...) . This worked great, but appears too shiny to use on the flat edges.
Anyone tried any method of brushing or sanding to replicate the darker gray on the flat edge?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
4个答案
最有帮助的答案
It's a complicated process, only the factory can do that and it can cost a lot
The case is first polished, then the iphone logo is covered with a protect film,then the case is sand brushed, 3 parts are fused together then anodized, and the edges are cut using precise tools. Then the protect film is removed and the case is anodized again
If the case is damaged, there is no way to perfectly restore it
这个答案有帮助吗?
得分 3
添加一条评论
You're not going to be able to replicate the same brushed aluminum look that it had when it left the factory. It's strongly recommended that you don't try to repair any scratches or defects with the casing, as you'll only get an uneven finish. Since you've already sanded the area where it was dropped, the only way to achieve an even finish would be to sand/polish the entire device to get rid of the texture on the rest of the device. Of course this would result in a flat finish, and not the brushed aluminum you started off with. You'd wanna mask off the Apple logo, as not to destroy the mirrored finish, if you were to try that method.
Polished iPhone 5
这个答案有帮助吗?
得分 2
添加一条评论
Test on scrap aluminum, and (guessing) a medium grit sanding stone (used to hone chisels) and straight, uniform strokes (and patience!) you should be able to get close.
这个答案有帮助吗?
得分 2
添加一条评论
My iPhone fell down on the floor by mistakenly. So I want to change the body of my iPhone. Now I have got a small scratch on the side of the iPhone. It's just above the silent button. Will you be able to replace it or should I buy a new case for the iPhone ? Please let me know if it's costing me. I'm now living in Dubai. Is there any chance for me to get a new case. I want my iPhone to look as if new one with original body. Golden colour.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
areising 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 13,495
