跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
Can't identify 4 parts after iPhone 4s disassembly
https://www.dropbox.com/s/syjjck4ob77dnz...
Almost done putting iphone 4s back together after doing water damage fix but can't figure out these last 4 parts
Thanks in advance for your help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
From left to right:
  • I'm not positive about this one, it may have been stuck to the mobo, but I'm not sure to what end, or where.
  • This looks like a rubber gapper, which sits under the EMI shields, to help cushion the chips against shock. I don't know which shield this one goes in, but I believe there is a space it fits in the underside of the mobo.
  • This is a rubber cushion that fits between the motherboard and the top of the metal frame. it wraps around the edge of the motherboard to the right of the rear facing camera, just to the left of the topmost screw in the connector cover plate.
  • This is the antenna grounding finger that goes to the right of the connector cover plate, over the stand-off screw, with the small screw holding it in place. The curved bit fits into the frame, and grounds the finger, and the flat arm sits on top of the antenna cable, after it's been clipped into the motherboard.
Hope this helps, if I can clarify anything, let me know.
~Des @ MRRU
这个答案有帮助吗?
得分 1
3条评论:
Thanks so much. Will check it out tomorrow. Looks like some do-overs in my future
完成的
Hi Des,
I do have some questions. I don't know where or what some of the locations are.
The connector cover and the standoff screw? The EMI plates?
完成的
Got the last piece with the prongs
完成的
添加一条评论
添加你的答案
Patti Drake 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 613
