Mac has new HDD, It won't recognize flash drive to boot.
Hey guys, first time asking a question. I've looked everywhere couldn't find my answer. So I have this mac that I got for real good deal. It obviously hard HDD problems because the owner said the batteries blew up. Everything was really slow with the old HDD. So I replaced the hard drive with 320 gb HDD that has been laying around. I did all the necessary work to make a bootable flash drive because I have another mac.
Then It does recognize the flash, after I click the bootable flash drive it shows this no go sign. Looks like a circle with diagonal cross, and after couple seconds it shuts off. I tried to boot it from DVD but it doesn't show at all. I tried to hit "c" and "option" button. but no help. Please give me a solution. I really want this bad boy to work!
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
What does the battery have to do with the hard drive. What's your other Mac?
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
1个答案
已选择的解决方案
Your flash drive has an OS that won't work on this system. It must be X 10.4.8 to MacOS: 10.7.5*
Details: *This system can run the last version of OS X 10.7 "Lion." However, although it has a 64-bit processor, it has a 32-bit EFI and is not capable of booting into 64-bit mode. It does not support "OpenCL" either. Please also note that OS X Lion is not capable of running Mac OS X apps originally written for the PowerPC processor as it does not support the "Rosetta" environment.
这个答案有帮助吗?
按维修分数 2
评论:
Thank you! I really appreciate your answer. It helps a lot!
添加一条评论
添加你的答案
Clarke 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 695
