iPhone 5c Broken Screen Replacement
When do you expect for you guys, or anyone else, for that matter to have replacement screens for the newest iPhone 5c? I had bad luck with a screen break and I can't get any luck with verizon or apple.
Thanks
Here is a good place to get a screen but you may want to wait for the price to drop, https://gounlock.com/details.php?itemId=...
这个答案有帮助吗?
Went I to apple store together mine replaced, as it broke very easily, I might add. And the only option I had since I didn't take insurance is buying a new phone!
这个答案有帮助吗?
I have a green iPhone 5c with a crack screen too. It also broke way too easily. Looking at the phone closely it is actually a bad design because the screen is not fully surrounded by the plastic casing so it is expose to easy cracking.
这个答案有帮助吗?
5C and 5 do NOT have the same digitizer. The connector is different. I don't think white 5C screens have started coming into the country yet for resell.
这个答案有帮助吗?
If your LCD is ok you can replace just the glass but I warn you it's a lot of work and you HAVE to take your time otherwise you will screw up and it won't look perfect.
这个答案有帮助吗?
I suggest that to get a LCD Screen with Digitizer Replacement Parts for Apple iPhone 5C and replace it by yourself, which will save a lot.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 33,482
