跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
iPhone 5c Broken Screen Replacement
When do you expect for you guys, or anyone else, for that matter to have replacement screens for the newest iPhone 5c? I had bad luck with a screen break and I can't get any luck with verizon or apple.
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
7个答案
已选择的解决方案
Here is a good place to get a screen but you may want to wait for the price to drop, https://gounlock.com/details.php?itemId=...
这个答案有帮助吗?
得分 2
添加一条评论
Went I to apple store together mine replaced, as it broke very easily, I might add. And the only option I had since I didn't take insurance is buying a new phone!
这个答案有帮助吗?
得分 0
添加一条评论
I have a green iPhone 5c with a crack screen too. It also broke way too easily. Looking at the phone closely it is actually a bad design because the screen is not fully surrounded by the plastic casing so it is expose to easy cracking.
这个答案有帮助吗?
得分 0
添加一条评论
5C and 5 do NOT have the same digitizer. The connector is different. I don't think white 5C screens have started coming into the country yet for resell.
这个答案有帮助吗?
得分 0
添加一条评论
If your LCD is ok you can replace just the glass but I warn you it's a lot of work and you HAVE to take your time otherwise you will screw up and it won't look perfect.
这个答案有帮助吗?
得分 0
添加一条评论
I suggest that to get a LCD Screen with Digitizer Replacement Parts for Apple iPhone 5C and replace it by yourself, which will save a lot.
这个答案有帮助吗?
得分 0
添加一条评论
Get a LCD Screen with Digitizer Replacement Parts for your iPhone 5C
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
hayden wolf 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 33,482
