2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
159 个问题 查看全部
Works fine on AC power but shuts down on battery.
MacBook Pro 15" Retina Display Mid 2013
My Macbook was setting on the table , in sleep mode and not connected to power adapter when a glass of wine was tipped over. The wine went straight across the table and into the Mac! Now it will not turn on at all on battery but if I connect the adapter it comes up fine. The battery shows 70% and not charging.
I took the Mac to Apple and they said to back it up and return it for repairs at fixed rate of $1240! Seems a little steep without really knowing the extent of the damage. Like I said it seems to work perfectly on AC. Are there other avenues to explore?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
善于维修,即天赋异禀。
与 #ImAGenius 分享您的维修故事
我们都是天才
1个答案
已选择的解决方案
First get it open and dried out! Here's how: MacBook Pro 15" Retina Display Early 2013 Lower Case Replacement
Next download and run Coconut battery to find the status of the battery then let us know your results: http://www.coconut-flavour.com
这个答案有帮助吗?
按维修分数 1
评论:
I dried it immediately, before ever applying power. Ran the Coconut app but do not know how to attach the file. Results: CURRENT CHARGE 65% 5419 mAh, max charge=8315mAh. Capacity 98% ; current 8315mAh, design capacity 8460mAh......MacBook Pro 10.1, age 17 weeks, Battery long cycle 19, Battery temp 30.3C , Battery power usage 0 watt.
Hi Deesau - so what ended up being the result? I see the stats on your battery, but according to that, your computer should function just fine. It's current charge was 65% and it's total capacity charge was still 98% of the original factory charge. So it should have run. What happened with this? Was the connector on the logic board or the cable from the battery affected? Just trying to follow up and find out for others who've run into the issue. Thanks
添加一条评论
添加你的答案
deesau 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 474
