跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
Why does my iPhone 4s keep turning off after a replaced battery?
I have had my Iphone 4S for about 20 months and last week it started turning off on it's own on and off. At first when the problem started, it would work no matter what when plugged in but then that wouldn't even work. When that started to happen I bought a new battery and replaced it but the problem never changed. The phone will turn on but when it turns on the apple logo is on the screen for about a minute then practically immediately after turning on and going to my lock screen it shuts back off on its own. The phone is out of warranty so it can't be replaced by Apple. Please help!!!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
4个答案
最有帮助的答案
I have a similar sounding issue. The forced power on trick helps me kick start the phone but then it keeps rebooting at random but short intervals.
I've tried a couple of different batteries and have previously swapped the dock connector but I don't think these are related.
Can anyone recognise the symptoms and suggest what the issue might be please
这个答案有帮助吗?
得分 1
添加一条评论
Hi Wyatt,
Just ensure that your iPhone is connected to DC input or has enough battery.
Try normal power-up:
Press the power/standby button and hold it there for a few seconds
If you tried the above for about 5-10 seconds but nothing happened, then try to force iPhone power-up.
To force it to power-up:
Press the Home button, hold it there, followed by the power/standby button, and hold it there when apple logo appears.
Hope it was helpful.
这个答案有帮助吗?
得分 0
添加一条评论
I have the same exact problem! I had my screen replaced by a telephone repair place so Apple refused to help. So I got another repairer to replace the battery, but to have it happen once more again. My phone would shut off at even 94% battery. The only way I could start it up again would be to plug it back into the wall to jump start it. Then, once it went back to lock screen, it would shut down again.
Will try the above process when it happens again.
这个答案有帮助吗?
得分 0
添加一条评论
I have similar issues but it doesn't turn off it just screens off and on after the timeout. so it'll be off, then randomly the screen shows then if I leave it sit for 30 seconds or whatever the screen goes back off and it just does this repetitively. It doesn't power on and off, just screen turns on and off....any ideas anyone?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
wyatt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 11,459
