跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
问题已关闭
Why Disk Utility gives error if I try to partition a sshd?
I replaced my old internal hd with a seagate 500 gb sshd sata III 2,5" (model ST500LM000) , but if I try to partition the disk, utility disk give me an input/output error.
How can i resolve it?
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Because your machine can not transfer data at SATA II speeds. You need to slow the drive down to SATA I speed, or, find a different drive.
Also it's not clear if you are trying to partition the boot disk... You can't do that. You have to boot from another source then use DU to partition the drive.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 602
