跳转到主内容
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 个问题 查看全部
iMac display turns black, it's getting worse.
Hello, i have an iMac 27'' i7 2.8 Late 2009.
I have the problem that my always turns black after a few seconds. I can start the system and most of the time log in but then it's over. I can get it to work again using the sleep/wake up button but only for a few seconds. When the display turns black, the system itself is still fully running and i can use it over my network with another iMac (remote thing). The problems started out of nowhere yesterday. Yesterday i could fix it by putting the brightness one tick lower than max., after I did that i could use the whole day (browsing,video game everything worked).
Now this morning it doesn't even work using lowest brightness.
Oh and it's completely black, I can't see anything using a flash light.
I can't really afford a new one or the fancy apple repair prices , so any help would be greatly appreciated!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Seems like you have a failing backlight, which since you have an LED screen would most likely mean a display replacement.
I would contact APPLE. They may still stand behind this problem, or. offer you (ask for) a depot repair which is a flat rate repair, the best price you'll find anywhere.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 2
10条评论:
I agree with machead here your display is likely having a problem, but it maybe the thermo sensor on the display thats shutting it down. Try installing Temperature Gauge from the Apple Apps Store or some other like app. That way you can monitor the sensors and the fans
完成的
Thank you machead and Dan for your answers. I'll contact Apple tomorrow and see what they say.
Meanwhile I did a temperature check with Temperature Gauge. I'm not sure but I think everything looks okay? (http://i.imgur.com/nKEIZ4h.png)
完成的
The platform controller looks like it's running hot. Are you using an external HD (using any port) or external display via ThunderBolt?
完成的
No not really, the only thing connected at the moment is the keyboard.
完成的
Enable logging in Temperature Gauge and Activity Monitor so you can catch the temps and what is running just when the display winks out. See if the temp is the same (hottest) on the controller each time you loose the display.
完成的
显示更多的5条评论
添加一条评论
添加你的答案
Luis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 4
总计 787
