Location of cylinder 6 on the Lexus ES300 engine?
Hi. I found this answer on wiki.answers.com, so I'm not entirely sure if it's correct. I'm sure the community will correct me if I happen to be wrong. "The number 6 cylinder is located on the drivers side front toward headlights, here is the entire order: pass side back by firewall = 1, center=3,drivers side back=5 and the front cylinders are: pass side front=2, center=4, drivers side front=6"
这个答案有帮助吗?
I replaced the coil on the #6 cylinder which was having an error, and can confirm that the #6 position is correct
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 74
总计 21,520
