How do I replace the front turn signal lamp?
The left turn signal flashes rapidly. I replace the fuse, then the rear turn signal lamp. I was going to replace the front turn signal lamp but there appears to be a lot of things in the way. Is there an easy way to replace the drivers-side turn signal lamp?
2条评论
Unless things have changed a lot, a rapid flashing usually indicates the flasher circuit has an issue, like a bad cap...
由 Dave 完成的
Hey! It's the other Dave!
由 Dave 完成的
