跳转到主内容
Repair information for PowerBook G4 Aluminum laptops with 15-inch displays.
320 个问题 查看全部
PowerBook Won't Charge Battery
I have a 15" Aluminum PowerBook 1.5 GHz PowerPC G4 running OSX 10.5.8
Recently the battery has stopped charging. In the menu bar I have a "not charging" next to the battery icon. I checked the battery with Coconut and it says the battery has a 79% capacity. I tried another batter from a friend since I thought that was the issue, but his battery was only 44% capacity according to Coconut. I tried his battery but it was also dead and didn't charge on my PowerBook at all.
I read about the DC board, and I'm hoping to get a new MacBook Pro when the Haswell chipset comes out, hopefully soon. I hate to spend $100 on a part for this laptop but is there any other option any one might see. I also read about resetting the PMU, which I've never heard of. Is this like zapping the pram? I remember that from my 8500 days.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Resetting will not "fix" a faulty DC in board. These go bad over time from wear and tear to the solder joints. If your's has never been replaced it's due. You might be able to prolong the life if you see under a magnifier that the solder is cracked or if the contacts appear lose. Soldering logic board/computer components is and advance DIY. You need special tools, solder and lots of practice.
It might be wiser to see if a local electronics repair shop can resolder the parts if they appear lose. If that fails you can still put in a replacement DC in board.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 2
1条评论:
So I just finished tearing down my PowerBook G4 and replaced the DC / Sound Board. I got one on Ebay for $40. I also replaced the right side USB board since that had stopped working some time ago. Well, the plug in adapter is still green and the battery monitor says (Not Charging) Coconut still says the same stats about the capacity.
This is so frustrating, especially since the tear down was no easy feat.
Does anyone have any other ideas what might be wrong? I tried using another battery from a friend to no avail.
完成的
添加一条评论
最有帮助的答案
Try your battery in the friends machine to see if it is OK. Next replace the battery connector. Check your machine to see if this is the right one: [关联产品丢失或禁用: IF154-033]
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Patrick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,484
