跳转到主内容
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405 个问题 查看全部
MacBook Pro Late 2011 won't power on
While connecting a LogiLink Solar Charger (http://logilink.com/showproduct/PA0055.h...) to my MacBook Pro via USB it went off immediately and shows no sign of life since.
The Magsafe light is neither green nor amber nor dim: it's off; the very same Magsafe unit however works flawlessly on another MacBook Pro, including the green/amber light.
When the battery indicator button is pressed, not a single led goes on, despite the battery was on 100% when the incident happened.
Needless to say, the MacBook does not power on. Simply put, it does totally nothing.
Could a fuse be blown or should I assume that the whole thing is toast? Any help is appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
In case your interested, the case is now solved.
I disconnected the battery and then connected the Magsafe unit: the MBP powered on and started the boot sequence. Disconnected the Magsafe, re-connected the battery and then re-connected the Magsafe: the MBP powered on again.
The battery indicator shows that the battery is completely discharged, but now it is charging again. I guess the incident did nothing good to it, but at least the MBP is up and running.
这个答案有帮助吗?
得分 2
1条评论:
Exact same thing happened to me and this fix worked. I did not need to boot it off of the Magsafe. Just disconnecting the battery connector, letting it sit for a few seconds, and then snapping it back on was all that was needed.
完成的
添加一条评论
添加你的答案
Peter N 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 518
