跳转到主内容
加入维修社区 - 创建账户
The Lenovo G570 is a 15-inch laptop announced in January 2011.
Some horiontal line is displaying in my laptop
I thought the reason might be due to loose connection to my laptop display. I tried to press my screen at corners but it does not works for me :( . So could you please tell what is the solution for this...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
2个答案
已选择的解决方案
Horizontal lines are often LCD display problems with the driver chips and/or the screen got a hit on the edge breaking the fragile connections to the driver chips.
In any case the panel assembly will likely need to be replaced. You can verify this by connecting to an external display if the external display image is not distorted then you know its the LCD display.
这个答案有帮助吗?
得分 2
添加一条评论
Hi,
Try reinstalling the drivers for your VGA if that did not solve the issue you have to replace your LCD. You can search and buy for your laptop model LCD from eBay.
Good Luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Anjani 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 28
总计 17,347
