跳转到主内容
A clothing iron, also called a flatiron, is a heated surface used to remove wrinkles from fabric.
85 个问题 查看全部
Why is my Iron not heating up? when powered on
How do I get the Sun beam Steam Iron to work again?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 9
2条评论
What's the model number?
完成的
I have the same problem now. Any chance that you get it to work again ?
完成的
添加一条评论
6个答案
已选择的解决方案
Get a multimeter. Check that the fuse is OK. If it is ok, open the cover at the back of the iron. Plug in the iron. Be careful not to get electrocuted. Check that the cables from the socket on the wall have power. place the leads of the multimeter on the live and neutral and check for 240V or 110v depending on your country. If no power here cable could have a problem.
If there is power here, turn of power and unplug socket. open top cover, you will see the heating element. Check for continuity between the ends of the element, If no continuity the element is dead and you need to buy a new iron. If it has continuity then check continuity of other components connected in series with the element. Some models a limit thermostat to prevent the iron from over heating. This looks like a small resistor about one centimeter long, if it has no continuity, cut it off and bypass it. It is a safety device that fails when it senses high temperatures in case the main control thermostat fails. If you can find a replacement replace it, if you cant find a replacement, you can use it and hope the main thermostat does not fail.
这个答案有帮助吗?
得分 10
1条评论:
replace cold iron
完成的
添加一条评论
Ensure that the unit is tightly plugged into a working outlet. Some units are equipped with a Motion Smart Auto Off technology. Moving the iron will cause it to begin to reheat. Are you getting a red or green light?
这个答案有帮助吗?
得分 3
8条评论:
I tried that but still cold. Red light is on. i
完成的
Is still green with no heating at all
完成的
the green light is blinking on my side but the red one not working
完成的
new one,
red
完成的
manandharmeena it it's new I would return it under warranty
完成的
显示更多的3条评论
添加一条评论
There is a small thermal fuse inline . This is usually on the red wire. Bypass this with a wire and check if it switches on. This happens a lot with the irons we use and i usually bypass the fuse if it blows a second one. But this is a suggestion and would be safer to replace the fuse by aoldering a new one in line
这个答案有帮助吗?
得分 2
2条评论:
I need to replace my thermal fuse in my iron but do not know the rating, the writing on the old one has gone. What is a recommended temperature rating? Are all irons the same?
完成的
Thanks can i know the thermal fuse rating for Black & decker model no X850
完成的
添加一条评论
Buy a new one, end of story
这个答案有帮助吗?
得分 1
1条评论:
yes new onr but on low indicater not on only high indicator on how
完成的
添加一条评论
Check the fuse in the plug this is common in electrical items to be blown
这个答案有帮助吗?
得分 0
2条评论:
no fuse in the plug
完成的
You must be using a 2 pins plug which is very dangerous in this high heat appliance. You need to use a 3 pins plug with the earth wire for safety reason.
完成的
添加一条评论
Hi
I have the same problem with my iron. I no longer believe that my iron can be repaired, unfortunately.
But maybe anyone can recommend me how to choose electrical home appliances?
I read a lot of different reviews and it helps me a little on choosing.
Thanks
这个答案有帮助吗?
得分 0
1条评论:
Hi,
1. Desired features -does it do all that you want
2. Good warranty - longer warranties to me show that the manufacturer has faith in their product and are prepared to back it
3. Good aesthetics and ease of use - you've got to look at it and use it ;-)
4. Good reviews - speaks for itself
5. Best that you can comfortably afford.
Go for the one that ticks most if not all of the boxes.
Just my 2 cents
完成的
添加一条评论
添加你的答案
sahmarry 将永远感激不已
浏览统计数据:
过去 24 小时: 16
过去 7 天: 165
过去 30 天: 596
总计 197,933
