跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
问题已关闭
Replaced back housing and now my home button is weird/broke
Hello
This is the first time i ask a question on this site, but ive been reading alot to solve other issues. So now i give it a go.
Ive replaced the back housing on my iPhone 5. First time i try and fix an iPhone 5, and everything went well, except my homebutton.
If i lift the screen 1mm from the case, the button works fine. If i take the screen out (still connected) and place it ontop of the caseing, then it also works fine.
If i put the screen down in right site, it works.
If i put the screen down in left site, it dosen't.
It makes zero seence to me at all.
i've checkede that the 2 connecters witch have to hit the screen on assembly fits and is placed correcly.
Anyone got a anwser for this?
Update 1:
Last night i found out that, if the phone dies of power, and starts op. It says it have to be connected to iTunes. When its connected iTunes says it found a phone for restore. I restore it, and when it powers up, it says connect to iTunes, and its the same all over again.
IF i lift the screen 1 mm as mentioned above, it starts normaly.
I really REALLY don't get it!
Update 2:
Last night i bought another iPhone 5 for parts. Once i opened it i found the flaw.
Aparently it was the 2 connectiors thats hitting the screen for the homebottom to work, that was placed 1mm to high. i disassemblyed the bottom and put it right together again.
However, i don't get how that messes with the software.
But it's fixed now!
Thank you all for the many many responses ;)
Great site to ask questions about iPhones..
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
it messes with the software because button is beeing pressed all the time, if connectors short :-)
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 168
