跳转到主内容
Hdmi to dvi on ps3, can u cut the wire and get sound
I understand that dvi Will not carry sound. but if u plug the hdmi in is there sound wires and if so is there anyway to cut into the wire and get to them to put a jack on. I've look online but found no wiring diagrams with wich wires are sound.thanks for any help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
评论:
what are you trying to set up?
完成的
添加一条评论
1个回答
最有帮助的答案
If you're trying to cut an HDMI cable and attach an RCA or 3.5 mm audio jack, no, you cannot do that, as HDMI is digital and those are analog. You can however get something like this and this if you're trying to get analog audio out of hdmi.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
gavin hirst 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 165
