跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2191 个问题 查看全部
Please Help! iPhone 4s - Black screen but phone is on and working
Hello all,
I've just bought a iphone 4s. The screen is black but the phone can be powered on. I can tell as the vibrate can be switched on and off. I can also power the phone down remembering the position of the "swipe to turn off".
I have replaced the screen but the result is still the same...black screen but the phone appears to be working.
Any help would be greatly appriciated.
Thanks,
James
Update
I'll just add that I have done a standard home button and power button reset, a restore through iTunes and a dfu restore. None of these made a difference.
Help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
8个答案
最有帮助的答案
Ok I have a blank screen but everything else seems to be working just fine. I've done two screen replacements now and both times I've been perplexed about one part that I can figure out where it goes. It's a rubber spacer or something that has a thin gap lengthwise across it. It always seems to pop out when Im taking apart the connections to the logic board. Anybody know what I'm talking about???
Also I noticed that this time the LCD screen on he top of the iPhone 4S is just barely pushed outward in the middle. I would absolutely love for one of these installs to go as planned. It's def emotionally draining when that much concentration and time is used up without achieving a result. Plz help if possible. Thanks
这个答案有帮助吗?
得分 1
添加一条评论
So here's what's happening. You have the 2 cables on your screen replacement, the longer more flimsy one is more than likely pinched. This will also cause your screen replacement to shift and not seat properly. What you'll need to do is get to the last step of the screen repair. At this point, the replacement screen is unscrewed from the bezel. At the top, close to the power button, seperate replacement screen from bezel being mindful of the cables. What you just did is freed the pinched cable. Now is time to reassemble. As your closing the gap between replacement screen and bezel, keep the longer flimsy cable taught as you seat the replacement screen to bezel. The replacement screen should fit like a glove! If it doesn't seat properly the first time, just readjust the long cable again. If it seats properly and you still have a black screen, remove replacement screen and inspect cables. This has happened in a few of my repairs. Just be patient and you'll get it.
这个答案有帮助吗?
得分 1
添加一条评论
Does the screen at least show the silver apple when you boot the phone?
这个答案有帮助吗?
得分 0
添加一条评论
This must be the problem with your display connector, as if it loosens then you might not get any display on your screen. The very first thing that you need to do is to get any other good and working LCD in order to verify where is the problem whether it is your LCD, Connector, display strip, connector etc. However there are a lot of things that you need to check. Here is a blog that has defined step by step solution in order to overcome this problem, i hope it will help you in resolving this problem.
http://blog.brokenlcds.com/iphone-4-disp...
这个答案有帮助吗?
得分 0
添加一条评论
I am a tech at Apple. You will most likely need a hardware replacement. If the reset and the restore did not help, it is most likely a hardware issue. I am sorry for your situation..
这个答案有帮助吗?
得分 0
添加一条评论
Had a similar problem. I would hard reset my Iphone 4s and it would turn on up to the apple logo but then would dim black completely. Knew it was running because I can hear the clicking from my lock screen. Tried everything but nothing was working. In desperation I simply asked siri, "Make it brighter" and low and behold, she made the screen brighter. I turned off "auto brightness" off right away. Five it a try If you can get Siri running..I had to get passed my lock screen though in order for me to access my Siri. Thank god I remembered the passcode without having to see the screen. Hope it works for you too
这个答案有帮助吗?
得分 0
添加一条评论
Apple Sucks, get a Droid! I've had a droid for 3 years, never had an issue at all. My wife and son have iphone's. They average an issue every 2 to 3 months. Apple just plain sucks!!!
这个答案有帮助吗?
得分 0
添加一条评论
i have a problem for i phone 4s phone working with sirri, but main screen is all black why ?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
James Glasby 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 33,157
