跳转到主内容
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405 个问题 查看全部
did not charge when I was doing my project
Hi,
I am a newby here, my MBP 15' (late 2011) did not charge when i was doing my project yesterday, the green light were disappeared, battery percentage dropped to 56%. I google the issue, I then realize that my battery is acting strange and please take a look at the MBP System Report stated as below: -
Manufacturer: SMP
Device Name: bq20z451
Pack Lot Code: 0
PCB Lot Code: 0
Firmware Version: 406
Hardware Revision: 2
Cell Revision: 158
Charge Information:
Charge Remaining (mAh): 469
Fully Charged: No
Charging: No
Full Charge Capacity (mAh): 6289
Health Information:
Cycle Count: 83
Condition: Normal
Battery Installed: Yes
Amperage (mA): 0
Voltage (mV): 11040
System Power Settings:
AC Power:
System Sleep Timer (Minutes): 10
Disk Sleep Timer (Minutes): 10
Display Sleep Timer (Minutes): 10
Wake on AC Change: No
Wake on Clamshell Open: Yes
Wake on LAN: Yes
Current Power Source: Yes
Display Sleep Uses Dim: Yes
GPUSwitch: 2
PrioritizeNetworkReachabilityOverSleep: 0
Standby Delay: 4200
Standby Enabled: 0
Battery Power:
Display Sleep Timer (Minutes): 2
GPUSwitch: 2
Reduce Brightness: Yes
Standby Delay: 4200
Standby Enabled: 0
Hardware Configuration:
UPS Installed: No
AC Charger Information:
Connected: Yes
Revision: 0x0000
Family: 0x0000
Serial Number: 0x00000000
Charging: No
I tried almost every mattered posted on the website such as SMC, reset PRAM but I still couldn't resolve the problem, after that my battery percentage went down to 7% and my battery is not charging!!! Is my battery died and needs to be replaced a new one? Any advise would be very much appreciated.
Thanks & regards
KL
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
I would first check your wall outlet - then try a different or new charger.
If there was no liquid damage or falls the DC-in board and battery should be ok. However if you've dropped, squeezed or stacked something on the laptop there could be internal damage.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
kenneth Liew 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 117
