跳转到主内容
加入维修社区 - 创建账户
Apple AirPort Extreme 型号 A1143 的维修和拆解指南。
After upgrading to 7.4.2 Air Disc won't connect anymore.
Hey folks!
I recently updated my AEB to 7.4.2 and it turns out that my MacBook is not able to connect to the Harddrive connected to the AEB. When 7.4.1 was installed (and after downgrading Firmware to 7.4.1) it worked and I could even use it for Backups with TimeMachine.
It's a used AEB, bought on Amazon a year ago, or so. That's why I don't know when it was built etc. But the Model No. is A1143, if this helps.
Would be thankful for any advices.
greets [m]
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
There seems to be a lot of issues with 7.4.2 version firmware for the Airport Extreme. Mine would lose connection to the disks regularly, and I'd have to restart the basestation (switch off or restart via Airport Utility) to get the connection back. I tried many things to resolve this, but nothing worked and in the end I rolled-back to 7.4.1 and everything is fine now, and has been for several months - much more reliable connection to disks attached to the basestation. So that's what I'd recommend.
The only issue is that Airport Utility sometimes warns me that a 'basestation is reporting issues" - that is just the basestation seeing there's a firmware upgrade available. Just ignore it.
This isn't really a fix, but it seems the only workaround I can find. Hope it helps.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Mario Schmiedel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 1,947
