跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
问题已关闭
iPhone 3G won't boot up?
I'm trying to fix this for someone and they said up until a day ago it was working fine now it won't boot up at all, it also won't show up in itunes at all
Could replacing the battery fix this issue?
I've opened it up and nothing appears to be damaged either
All it will do (even when plugged in) is show a black screen nothing lights up or appears to power on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
This looks more like a software problem, you should restore the iPhone to fix it. If iTunes can't see the device, put it in DFU mode, when you'll connect it iTunes will ask you if you want to restore the phone.
Note that if you restore the iPhone you'll lose all the data you didn't backup.
http://theiphonewiki.com/wiki/DFU_Mode
Here it's explained how to enter DFU mode.
Let me know if it works.
这个答案有帮助吗?
得分 0
2条评论:
Yeah I know how to do DFU mode and I've tried that but iTunes won't see it (I already said that) and I know that restoring wipes all the data.
完成的
Sorry, my mistake, I didn't read it properly.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,613
