跳转到主内容
Apple的 MacBook Pro 的產品線是專為可望極致效能專業使用者所打造。MacBook Pro 产品线包括了MacBook Pro 13" (一體成型機身款), MacBook Pro 15", MacBook Pro 15"(一體成型機款), MacBook Pro 17" 和 MacBook Pro 17" (一體成型機款)。
20008 个问题 查看全部
Water Damage Repair: Clean as a whistle but won't boot?
I've inherited a mid-2012 MacBook Pro that's background story was some wine spilled and the computer no longer works. I've had some luck with repairing liquid damaged MacBooks so I decided to give this a shot.
I've disassembled and cleaned the logic board and mag-safe DC-in twice over. First time utilizing medical grade denatured alcohol then deionized water followed by 72 hours of drying in a rice bin.
That didn't work, so I gave mayor's suggestion a shot of soaking the board in detergent and hot water followed by a drying spell.. no luck.
The computer shows no signs of life. With the mag safe plugged in the light on the mag safe does not glow, the indicator lights on the side does not blink and no part of the logic board gets warm to the touch. Utilizing battery power, the indicator lights do not show the battery life status nor will the computer boot.
Is this guy a goner or is there something I'm overlooking? I think he still has some life in him but it may just be over my skill set. Thanks in advanced!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Yes you could be overlooking a fuse or burned/shorted components or connectors. Unfortunately some of the cleaning may have removed burn marks that would point to the damage. Usually you have to go over the board with a magnifier looking for burn marks or swollen components. I am not certain if these models had a fuses (some models do).
You'd probably need access to the test unit that the factory runs on boards to find the problem so, IMHO, the only DIY repair would be to replace the logic board. . . which may not be a complete loss as you could put the fastest board/processor for that model sequence in as an upgrade.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 2
添加一条评论
Hi, I also found that after a spill frequently the power button will have shortened out. It is part of the keyboard assembly, and can be changed by replacing the keyboard. Inexpensive in parts, but labour intensive,,,some 100 tiny screws and all guts have to come out first. But it worked for me on a spill damaged machine.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alex 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 600
