cycle lights blink washer will not run
washer will not run . no codes, cycle light will blink once when start is pushed
Unplug it for 5 minutes to allow it to reset then plug it back in and see if it gives you any codes.
这个答案有帮助吗?
the door lock light didn't come on. when I unplugged the electric and plugged it back in the door light came on. it ran thru a couple minutes then shut off when the door light went out. can you help me? thank you.
fred
这个答案有帮助吗?
when i put a load in it starts and then stops and the light start blinking and i have to move the cloths around in the drum - or take some cloths out - but that only works sometimes.
这个答案有帮助吗?
Washer stopped with twelve minutes left on the timer clothes are dry enough to take out.the washer will not restart. I unpluged the machine for five minutes and when plugged back in no code appeared. When it was plugged back in a real low hum could be heard but still will not do anything
这个答案有帮助吗?
After turning power on I push the start button and hear a humming noise. Please help
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,097
